Valves/Springs/Retainers
Old 10-14-2009, 07:22 AM
  #51
JoeyBalls's Avatar
I have decided to go with new AP2 Valves, Guide valves and retainers (OEM)
I am also going with decking the head surface, doing a 3 angle valve job, checking for cracks, hot tank cleaning and full assembly. I am only really pushing the car (PSI) wise when I will be spraying meth so the Valves hopefully will not be under extreme heat
Old 10-14-2009, 09:30 AM
  #52
s2000Junky's Avatar
^^^ Sounds reasonable to me
Old 10-14-2009, 12:06 PM
  #53
siadam's Avatar
I'm stock for now, and pushing for the same numbers, lol.
Old 10-14-2009, 07:12 PM
  #54
Spoolin's Avatar
Have any of you guys seen the difference between the supertech valves and oem? The guy building my head said the oem valve stems are skinny and was why they are heat sensitive and will warp and eventually snap..
Old 10-14-2009, 10:47 PM
  #55
TRBOKEV's Avatar
Yes there is a BIG difference.
I have some pics somewhere of my supertech inconel exhaust valves...exhaust are thick at the stem to head radius and intake are back cut.
Old 10-15-2009, 05:36 AM
  #56
JoeyBalls's Avatar
When my motor goes pop I will run the Supertech stuff, for now I just went with new AP2 OEM stuff, I am WAY WAY WAY overbudget on this build.
Old 10-15-2009, 09:43 AM
  #57
HiVolume's Avatar
PM me if you need Ferrea valve guides for cheap.
umair
04-23-2015 06:23 AM
S2K_Vtec
04-15-2014 11:38 AM
jaundice
10-14-2011 06:25 AM
danhinton
08-01-2011 09:08 PM
jaundice
01-23-2011 03:34 PM
Quick Reply: Valves/Springs/Retainers
