Valves/Springs/Retainers
Old 09-08-2009, 10:42 AM
AndyFloyd's Avatar
why do you need aftermarket stuff when OEM is working perfectly. Unless I pull my head off I am gonna rock all my stock stuff for as long as I can. It doesnt seem to be showing wear and this stuff isnt necessary honestly. Its overbuilding I guess but why?
Old 09-08-2009, 10:47 AM
JoeyBalls's Avatar
yeah, I am pulling my head off when I throw the 3mm Gasket in, it was more an "idea", I dunno if anything is bent or needs replacement, so I figured while i had the head off, now would be a good time to upgrade the valvetrain parts (if I plan to do so). I do not intend to raise redline, so new valvetrain parts may be pointless, I am not sure thats why I am asking.
OEM may be fine for an unmodded N/A S2000, however I plan on pushing this motor to 550RWHP so I thought upgrading the valvetrain may be a good idea.
I don't mind spending the $$ if it will help, again I am not looking to gain power from this, just trying to make the moving parts stronger
Old 09-08-2009, 10:49 AM
AndyFloyd's Avatar
OEM may be fine for an unmodded N/A S2000, however if I plan on pushing this motor to 550RWHP so I thought upgrading the valvetrain may be a good idea..
I didnt know the head was coming off, might as well right.
Old 09-08-2009, 10:51 AM
JoeyBalls's Avatar
, yeah I would like to keep stock CR, but for the power I want I am going to have to use the 3mm H/G. I am sending the head out to make sure its not warped at all.
To be honest sending the motor out and getting built for $3,500 at Laskey is seeming more and more like a good idea. Ill see how well this H/G thing works out
Old 09-08-2009, 10:55 AM
AndyFloyd's Avatar
I like to run 11psi on stock HG....I made 402whp dynojet on that boost. Then when you wanna be crazy have a racegas map. Thats just me.
Old 09-08-2009, 11:05 AM
camuman's Avatar
this gets my vote. 9.x-10.0:1 CR built motor. whoop whoop
mine ever dies this is what i am going to do.
Old 09-08-2009, 11:06 AM
AndyFloyd's Avatar
same...ill rock this stock motor as long as it wants to live. When it doesnt ill get a built block.
Old 09-08-2009, 11:08 AM
JoeyBalls's Avatar
^ Yup, hopefully this one will last a long time
Old 09-08-2009, 11:14 AM
spectacle's Avatar
If you're not raising the redline I think its pointless. But if you've got the $$$$$ to burn, can't hurt?
Old 09-08-2009, 11:28 AM
rob!'s Avatar
just keep the ap2 stuff. it works.
Quick Reply: Valves/Springs/Retainers
