To valve or not to valve...
Old 11-27-2011, 11:04 AM
B5254T4's Avatar
Default To valve or not to valve...
I´ll start my head build this week but can´t decide on parts/brands. I think I´ll go Supertech dual springs and titanium retainers, never heard anything bad about them.
I heard the exhaust valves can drop due to the heat, want to upgrade them but what about the intake ones, waste of cash on a low milage head? Hmmm...
Old 11-27-2011, 11:40 AM
DFWs2k's Avatar
can i have your old stock valves
Old 11-27-2011, 12:01 PM
B5254T4's Avatar
Should add that I aim for 800+whp and maybe a fast visit at 10.000rpm just or fun.
Old 11-27-2011, 12:03 PM
_Ninja_'s Avatar
I would upgrade both. Stainless steel black nitrided intake valves and inconel exhaust valves.
Old 11-27-2011, 12:10 PM
Corey Maurer's Avatar
Hit up laskey Racing, I just had my head done by him, awesome communication, options, and turn around!
Old 11-27-2011, 12:15 PM
DFWs2k's Avatar
While you are in there, I don't see why you wouldn't upgrade both.
Sent using free Tapatalk - Android FTW
Old 11-27-2011, 12:21 PM
B5254T4's Avatar
Changing stuff can be a downgrade sometimes, these engines are awesome and could have good valves from start.
Thanks, will do both. Ferrea? Other good options?
Old 11-27-2011, 12:53 PM
looksexyS2000's Avatar
if you are going 800whp supertech should be plenty
Old 11-27-2011, 12:56 PM
Banned
wadzii's Avatar
For drag cars making power in the 900+ range we use valves with thicker stems and a different valve job to help the stuff last longer.
Also, supertech has stiffer spring availability than Ferrea.. I think ferrea taps out at around 100lbs on the seat, supertech goes up to 120 or so if I remember correctly.
Old 11-27-2011, 01:13 PM
B5254T4's Avatar
Interesting, thicker valve stems should mean more weight? Or do you use other materials? We used titanium valves in a customer engine a while ago, is that common in these engines? Worth it?
Thanks guys, really helps to get your opinions.
Quick Reply: To valve or not to valve...
