Valve Adjustment with Vortech SC + Aftercooler?
Has anyone ever tried to do a valve adjustment with a Vortech SC and Aftercooler without removing or loosening anything, or is this impossible?
I found 1 thread saying that it is possible, but they didn't explain how they were able to even reach the crank pulley from the top.
TIA
TIA
Maybe with the plugs out you can rotate the engine with the belts/pulleys?
-- Chuck
-- Chuck
if your belt is tensioned right and the plugs are out you can turn the blower pulley just remember righty tghty don't loosen the pulley bolt on the blower. its how i adjust mine though i run a comptech sos hybrid setup
