Vacuum but no Boost
Old 07-27-2011, 02:44 PM
starrman's Avatar
Default Vacuum but no Boost
I have my AEM digital boost gauge hooked up directly to the intake manifold, it only reads vacuum, and when in boost, it goes to zero and stops. I tested the gauge with a tire pump and it will show boost. Is this just a bad place to hook it up? Suggestions please!
Arrow pointing to vacuum line to gauge:
Old 07-27-2011, 03:20 PM
camuman's Avatar
U sure your actually building boost? That place is fine to read boost.
Old 07-27-2011, 04:08 PM
starrman's Avatar
Well I cant prove it, since the gauge won't work, but the butt dyno says yes.
Old 07-27-2011, 04:14 PM
Suzuka_Joe's Avatar
boost leaks?
Old 07-27-2011, 04:21 PM
starrman's Avatar
checked, cant find any...had one at the aftercooler...but fixed that.
Old 07-27-2011, 05:31 PM
GO-AUTOWORKS's Avatar
That source will work to feed a gauge. Are your datalogues reflecting any boost?
Old 07-27-2011, 05:51 PM
starrman's Avatar
I am taking to tuner on Wednesday, will find out then. Thanks for all the help.
Old 07-27-2011, 06:41 PM
steven975's Avatar
what happens if you blow into the hose connected to the gauge?
I can make 2psi doing that.
Old 07-27-2011, 07:06 PM
starrman's Avatar
I used a tire pump and created 18psi.
OK, so now I am thinking I have a leak, but there are only 2 places for a SC to leak, from blower to aftercooler, and from after cooler to throttle body/intake... and everything is tight as can be? Am I missing something?
Old 07-28-2011, 07:01 AM
icemans2k02's Avatar
Belt slpping maybe? Even then I would think you would make SOME boost.
Quick Reply: Vacuum but no Boost
