The Unofficial GT3076R Greddy Turbo Kit Upgrade
#141
I just wanted to make this comment as the first post is a little confusing.
The gt3071 linked previously in the thread will bolt right upto the hot side of the greddy kit. The OP only used the spacer for the manifold to fit the tomei exhaust housing and make a larger downpipe. If you look at one of the pics you'll see that he actually has the greddy turbo bolted to the manifold and tomei housing (he's using it to mockup the new downpipe he's making).
So, the hot side is a 100% bolt on. Only modifications required are the wastegate actuator and bracket need to be modified, turbo intake, and turbo outlet. Of course, the oil input and drain as well as the coolant input and output will need to be modified, but that should be obvious.
