The Ultimate GReddy Turbo Kit Thread
#952
Originally Posted by chViETnk,Aug 21 2010, 01:07 PM
...my tuner said it should be fine to make the drive to the shop...
1 =/= 2
2 =/=1
2 > 1 though. LOL
#953
Originally Posted by NFRs2000NYC,Aug 20 2010, 05:54 AM
For those that are having heat issues in warmer climates (FL, AZ, CA, etc,) for the summer (hot months) open your hood, and look at the TOP of the firewall. See that rubber gasket type thing on the top? Remove it, and install it back when the temps drop.
#954
He's not talking about that... he's talking about the weather stripping on the top of the plastic on top of the firewall. The long weather strip that seals the hood from the back.
That's what he means by the "TOP of the firewall."
#955
Originally Posted by lude9285,Jul 28 2010, 12:19 PM
Hey Greddy guys,
Please help...
So i just moved my S to Avon Colorado(ele.8000feet) from Socal today...im running the greddy kit @ 10psi with emanasge ultimate tuned at sea level. Since thats were she was tuned it has always ran great (AFR stayed consistently at 11's with wide open throttle). i knew it wasnt going to run exactly the same up here but i figurered id lose a few horse and maybe it would run a little richer with the thin air. but the AFR is all over the place. sometimes it holds at high 13's but i saw it go to 16 under full throttle! i only drove it for a few minutes this afternoon and just parked it until i find some info out. it seems to hesitate too while under boost.
what are safe AFRs ? whats the highest # i should see with wide open throttle?
i havent had much luck calling around the denver area for a retune. nobody wants to deal with or has experience with emanage.
any advise/info would be greatly appreciated!
super bummed since ive been waiting so long to get the car out here and it pulled soo nice in socal.
Joel
Please help...
Joel
The gas up there is horrifically crappy (second only to southern Utah). Get a tank of 93 from the gas station in silverthorne and see what happens. Even though in theory you can lower octane with elevation, you have not adjusted boost, and the engine loads particularly are way off what you were tuned for. You will also find that the severe temperature changes are also probably outside of what you were tuned for.
#958
Originally Posted by chViETnk,Aug 28 2010, 11:18 PM
hey, was wondering how did you guys screw this bolt in? there is barely any room to work with.
#959
Originally Posted by Chris_Lum,Aug 29 2010, 12:47 AM
loosen the V-band clamp on the turbo and rotate the compressor housing a little, so you have enough clearance to put a bolt in with a socket wrench.
