The Ultimate GReddy Turbo Kit Thread
#761
The first page talks about the Bov. It doesn't come with it and if u want one you have to have the flange added for it. A bov voids carb eo.
Any air that passes into the engine can't leave until it passes thru a cat.
#762
Hi guys i just purchased a s2k with a greddy installed. I want to remove it and have it running back to stock.
How hard is it to remove. The previous owner does not have the installation manuals anymore so where can I source one or is there a DIY i could follow?
Would I need to worry about anything? Removing the piggyback will my stock ECU relearn everything?
Also i was giving only the exhaust manifold and airbox. Are there any other stock parts that im missing here?
Cheers
Cheers
#764
Originally Posted by jari8378,Dec 22 2009, 11:08 PM
^^ You should just pay someone to put it back to stock.
Replace injectors, fuel pump, airbox, manifold, filtre etc. anything i've missed?
So there isnt a instructional manual or DIY anywhere lying around?
Cheers
#766
Cheers
Cheers
#768
just a quick question,
is it recommended to use an aftermarket standalone ecu instead of the e-manager? if so what do you people use?
does the e-manager relearn anything which would in term alter the initial tune, making it less effective?
#769
emanage only is "tuned" in positive pressure, or boost.
Under boost the car's ECU runs the show.
Emanage is only "Good" when you have a local knowledgeable tuner in the area. If all the local performance shops only tune hondata, EMS. Then i would opt for a standalone.
