The Ultimate GReddy Turbo Kit Thread
Old 10-11-2009, 03:20 PM
  #711
sammy21c's Avatar
Originally Posted by JoeyBalls,Oct 10 2009, 08:33 PM
Sammy, I had bad creep as well, get a HFC it willgive the greatest amount of flow without creep.
Get heat range 8 plugs.........
Yes, and I am also pulling out the turbo this week to port the wastegate. Thanks.
Old 10-17-2009, 04:53 AM
  #712
supratoy's Avatar
Hi,
Im a newbie to this site but Im about to buy a greddy turbo s2000 over in the uk and will be tracking the car next year but I know people where saying when this kit came out its not good for track as its producing to much heat.
Just wanting to know if anyone has been on track with this kit yet or know anyone that has?
If so did anything go wrong or what kind of exhaust, oil temps etc where people getting?
Thanks
Old 10-25-2009, 11:52 PM
  #713
DarrenDriven's Avatar
My own personal experiences:
https://www.s2ki.com/forums/index.php?showtopic=740825
Old 10-26-2009, 01:16 PM
  #714
itlynstalyn's Avatar
Anyone know where to find a T25 turbo blanket? I can't seem to find one for the life of me.
Old 10-26-2009, 02:10 PM
  #715
chad86's Avatar
Originally Posted by supratoy,Oct 17 2009, 04:53 AM
Hi,
Thanks
I have not been to a track, but I have auto-X'd and it was awesome.. Never went above the stock 3 bars for temp..( only gott boost and wideband)
Old 10-26-2009, 04:54 PM
  #716
edomund's Avatar
itlynstalyn, I bought a T3-T4 blanket off ebay & it fit.
You have to trim it to fit our wastegate acuator arm. Just use a sharp pair of shears, it's pretty easy.
Old 10-27-2009, 11:46 AM
  #717
Mrfixit687's Avatar
Does anyone know how the iat sensor is secured into the charge pipe going into tb on the DBW kits?
Old 10-27-2009, 11:48 AM
  #718
Chris_Lum's Avatar
i haven't seen a production model, but i think it's just a rubber grommet that you stick the IAT into.
Old 10-27-2009, 01:33 PM
  #719
lude9285's Avatar
I got my car dynoed today @ HBspeed in SoCal to get a baseline reading:
204.5hp
137.4 Tq
Ap1 w/ 102k on it. Only mods are upgraded valvetrain (Supertech Stainless Steel Valves, Dual Valve Springs, Ti Retainers, and APR Head Studs)
I was really happy with the results given its age/mileage!
Does anyone know if HBspeed's DYNOmite test reads high?
I also did a compression test and it reads 180 across the board!
My question is:
Will i produce good numbers with the greddy kit having lower compression?
I know lower compression is good for boosting but isn't the greddy kit designed for higher compression (225ish)?
How will the kit function with my compression? ( I'm looking to be around 300whp)
http://s225.photobucket.com/albums/dd156/l...10pics031-1.jpg
Thanks in advance!
Old 10-27-2009, 01:48 PM
  #720
chad86's Avatar
Its hard to compare the compression tests because every tester reads different.. Basically it is just used for amking sure one of the cylinders is shot.. In your instance, the readings were all the same meaning it is in good shape that way.. If that dyno is some what accurate then the motor is strong.... The compression being lower would mean the motor is weak.. ( not good for boosting).. Lower compression ratio is what you want... I would say u are good to boost, but the best way to determine a engines health is a leak down test...
Quick Reply: The Ultimate GReddy Turbo Kit Thread
