The Ultimate GReddy Turbo Kit Thread
#352
yes you could run a 70mm single and a berk HFC, but the cold weather is also a factor, so when it's cold you may have more creep then when it's warm out. If you live south you should have fewer problems then people up north.
#353
Originally Posted by Josh_With_The_S2K,Apr 16 2009, 12:43 AM
So on that note the T1R 70RT would most likely have boost creep than?
#354
Originally Posted by Chris_Lum,Apr 16 2009, 08:47 AM
likely with a test pipe. no creep with stock cat, and maybe no creep with a HFC.
- Josh
#355
guys, what are the nut size for the exh manifold studs? i guess i'm missing one when i inspect my car, probably didn't tighten enough on this end piece, or maybe i just never got it on, see pic below
#357
#360
so i called the local dealership and picked up the bolts, 3 bucks a pop, didn't want to wait for shipping from magistic...
pics...
there were 2 missing , one on the very end towards the filter, one on the lower side of runner 2.
the bottom one was A BITCH to fasten, check your bolts often guys, and i checked all other bolts, there were one, the 3rd one on top i could turn about 1/4 of a turn,
pics...
