The Ultimate GReddy Turbo Kit Thread
Old 10-15-2012, 06:30 AM
  #1551
Chris_Lum's Avatar
Originally Posted by S2KCHRIS305
chris lum ? anyone? bump!
i think it's your solenoid too. although i only have experience with a greddy solenoid, mine never got very hot. i'd replace your vac lines (you never know if there is a pin sized hole in any of the lines) then if that doesn't fix it, replace the solenoid or borrow someone's working unit for troubleshooting.
Old 10-19-2012, 09:57 AM
  #1552
S2KCHRIS305's Avatar
sorry for the long wait to reply , but yea il be getting a new mac soon ,also will bad heat soak cause not to run full boost ? i notice my car jumps from 8 to 9 bars on the gauge , i think 8 bars is where it should , also the engine bay is a oven when you open the hood after a couple runs .
Old 10-20-2012, 09:59 AM
  #1553
nick300zx's Avatar
Hi guys been back to my tuner with a few changes, changed the intercooler for a much larger version and swaped some vac lines around, was hoping this had it sorted. Did a smoke test to check boost leeks, all was good so did a power run up 40bhp from last time with boost holding solid at 9 psi so now up to 240ish bhp. But now we can't get the vtec to kick in? Its been set at 7k on the e manage but at 7krpm nothing happens, oil levels are fine so I can't see why it wont be working as it did before I went turbo. Only thing I can think is that my oil pressure is to low or a blockage in the lines, if it was this would the stock ecu prevent vtec engageing or will the emanage take over and try make it work?
Old 10-20-2012, 11:54 PM
  #1554
Kitesurfer s2000's Avatar
You need to test that the greddy emu is giving out the signal to the vetec solenoid mate could be your wiring.
Old 10-21-2012, 12:11 AM
  #1555
nick300zx's Avatar
They plugged some gadget and it measured a signal going to the vtec solinoid but nothing happened when it is meant to kick in, tunner said it could be a blockage in the gause filter in the vtec solinoid, un less the chap who had it before has done somthing crazy with the wire's for the gemu
Old 11-09-2012, 01:33 PM
  #1556
can any one show me some pics or links of peoples intake setups ? i wanna do a different setup to see if i can get a lil more power out of this kit . was thinking of running 3inch intake piping. what you guys think ? also what size exhaust works best ? and can anyone post some dyno graphs of the pfab manifold actually gaining power over the greddy manifold?
Old 11-09-2012, 04:04 PM
  #1557
RedSunS2K's Avatar
Try not to spend too much money on the Greddy Kit. I don't think a bigger intake set up will give you any gains. Very minimal gains at best. Making a CAI style intake would probably help.
Old 11-09-2012, 05:24 PM
  #1558
Im gonna play around with my greddy kit before I go bigger, I heard CAI style might lose power because of the extra piping. And I don't know if I'll ever go bigger, I think this kit is perfect for a daily driver, I don't wanna be relocating my battery n AC lines just yet, maybe I will when I get a new daily. So far im at 360whp with the greddy kit with stock.exhaust so there is still a lil more power to be made
Old 11-09-2012, 08:54 PM
  #1559
RedSunS2K's Avatar
If your at 360 I think you may have a record breaker on your hands. I remember reading a thread where the highest on the greddy was 330 using e86 gas or meth injection.
Old 11-09-2012, 09:22 PM
  #1560
liquid_helix136's Avatar
^^ Who knows what dyno he's using though. He could be on Church's dyno which reads flywheel hp while the others were reading Rear wheel power
Quick Reply: The Ultimate GReddy Turbo Kit Thread
