The Ultimate GReddy Turbo Kit Thread
Old 06-28-2011, 11:43 AM
  #1151
guamie's Avatar
has anyone replaced the air greddy air filter? any suggestions?
Old 06-28-2011, 12:09 PM
  #1152
Kitesurfer s2000's Avatar
I just gave the filter a hair cut and moved it down to the front bumper .Planning on getting rid of my hybrid greddy turbo hotside getting a GT3076r coming in the post
Old 06-28-2011, 02:48 PM
  #1153
Round 3's Avatar
does anyone have all the I.D for the couplers on the kit? I dont have access to my car at the moment and wanted to order some 3ply couplers and t bolts before I get back. thanks
Old 06-28-2011, 03:26 PM
  #1154
xervous36's Avatar
Any pics? I'm thinking about doing the same...
Old 06-28-2011, 11:24 PM
  #1155
Old 06-29-2011, 05:26 AM
  #1156
Nyther's Avatar
Might be better to ask my question also in the GReddy thread,
since i completed the build, the boost ( which was set to 10.5 psi according to the previously owner ) actes strange..
yesterday, while driving in very HOT weather ( 90+ fahrenheit ) it started to overboost suddenly.. which it usually doesnt do. ( yesterday was really hot, we normally barely ever going over 70+ fahrenheit ) So i started to think it might be the weather, but that should LOWER boost, not increase...
I usually have a solid 10.5 PSI of full boost but yesterday it went up anywhere to 12.5-14 PSI....
( i checked the vacuum line, it's good )
I DID ported the wastegate before the install, and im running a 3"berk ehaderback WITH HFC Cat.
One thing that i noticed during the instal, is that i needed alot of force to put the actuator arm on the wastegate flapper. I'm GUESSING it's NOT a 3.5 turn back from a zero point like mentioned in some GReddy wastegate actuator arm settings ( which should give 8psi if i'm correct )
Perhaps it's turned alot tighter than just 3.5 turns, making the turbo running higher boost and perhaps causing the little overboosting issue.
( the overboosting occurs already at 5000RPM! )
What do you guys think?
I also DO NOT have a boost controller, but i'm thinking of a profec B spec II...
I just need her to run a STEADY boost so i can have her tuned without overboosting issue's..
Hope some GReddy owners can help me out!
Old 07-01-2011, 08:55 AM
  #1157
Nyther's Avatar
Anyone?
Old 07-02-2011, 06:59 AM
  #1158
Round 3's Avatar
its gotta be the actuator rod if you adjusted it. Temperature plays a big role too. what is your air fuels? Usually the hotter it is the leaner your car runs.
Old 07-02-2011, 11:53 AM
  #1159
chViETnk's Avatar
anyone have a basemap for the aem ems 1052? thanks
Old 07-02-2011, 12:40 PM
  #1160
Nyther's Avatar
Well the previous owner adjusted it, like i said in my previous post, the actuator rod needs to go on the wastegate flapper with LOTS of force, so im assuming that when the wastegate reads 8psi, the boosts needs to rise a bit until it really starts to move.. Im guessing this would be my case..
But i still find it strange that the hot weather made it go up...
Im running 11-12.5 AFs...
Quick Reply: The Ultimate GReddy Turbo Kit Thread
