Turbo's and cams
Old 03-01-2007, 05:40 AM
slimjim8201's Avatar
How much power are you trying to get out of the engine? What are your goals? If you are going for 300-350 rwhp, go with the GT3071. 350-450, a GT3076. For 450+ go with a GT35.
If you size the turbo right, lag will not be an issue. I reach full spool at a little over 5,000 RPM. Anything between 4,000 and 9,000 RPM and the turbo spools VERY VERY quickly
Old 03-01-2007, 01:22 PM
Tyraid2K's Avatar
Cams are cool but they just aren't practical on this engine, did the FI BC cams make any power?
Old 03-01-2007, 04:43 PM
VashRacing's Avatar
I want my car to put out 300-350 rwhp. Other then to get more power i want more throttle responce with little lag. Im looking into getting a pulley kit from ricks and a light weight flywheel.
Old 03-01-2007, 05:33 PM
Spec_Ops2087's Avatar
They lost power as just about every aftermarket cam has...
Old 03-01-2007, 08:31 PM
timg's Avatar
That sounds just like a 3071R to me.
Tim
Old 03-02-2007, 04:57 AM
Tim
Sounds about right to me.
Old 03-03-2007, 05:56 PM
VashRacing's Avatar
Thanks for all the advice
Old 03-03-2007, 09:37 PM
JayStyles662's Avatar
To my knowledge the only cams to make power in our cars where the Stock ones or Skunk 2 FI cams....A Friend of mine switch his 2.0 Exhaust cam out to a 2.2 Exhaust cam amd mad about 20RWHP over his stock 2.0 cam...His peak power only changed a little bit 5 maybe 10 RWHP....Also there are some people putting in NA cam with their FI setups...I havent seen any dynos or info on those yet though.
Old 03-05-2007, 06:44 AM
jakub2000's Avatar
turbo lag with a modern properly sized turbo is a myth fro the past, dont worry
Luke530
06-11-2007 05:34 PM
JayStyles662
04-30-2007 12:41 PM
AndyDoh
08-20-2003 07:28 AM
Quick Reply: Turbo's and cams
