TURBO OR S/C EXHAUST QUESTION
Old 12-15-2014, 10:44 AM
Sideways's Avatar
Originally Posted by Redline S2K
A lot of the high horsepower SC guys don't run larger than 70mm. I think sideways runs stock and is over 500.
Sideways is running a full 3 inch dual with a Hytech header.
Old 12-15-2014, 11:10 AM
s2000Junky's Avatar
Stock head = stock diameter piping on an SC car. Any exhaust on a turbo car is a restriction, so bigger the better. Its two different operating principals between turbo and SC. Sideways breaks the rule with his SC because of his extensive head porting work, compression ratio and custom cam timing.
Old 12-15-2014, 12:16 PM
beaudin223's Avatar
ok so i should just do 60 mm test pipe from invidia and do 2.5 inch strait to the back ?
Old 12-15-2014, 12:25 PM
06S2k07Si's Avatar
60mm piping is 2.36" equivalent. 63mm is 2.5".
Old 12-15-2014, 12:31 PM
beaudin223's Avatar
but did 63 mm test pipe exist ? its a big deal to do 60 mm test pipe and 2.5 after ?
Old 12-15-2014, 12:51 PM
06S2k07Si's Avatar
Yes 63 exists...ideally one should match sizes when possible.
Old 12-15-2014, 01:13 PM
beaudin223's Avatar
ok i understand , so i should get berk test pipe 63 mm but my question is i need high flow cat in or without ? i dont have pollution emision test in my country so it not boter me , the best option for my supercharger is Js racing headers + 63 mm test pipe without cat or with it and 2.5 inch full exhaust ? i should change something ?
Old 12-15-2014, 01:39 PM
KaNgArOo's Avatar
3" is best for everything. Except meeting SOund DB levels.
Old 12-15-2014, 02:03 PM
06S2k07Si's Avatar
Sounds good! Bottom line is that there isn't a huge difference in any at about a 400whp level. I personally recommend a quiet system over a loud one...you will most likely get sick of it. Good luck Sir!
Old 12-15-2014, 02:42 PM
JUSTINTHECOASTIE's Avatar
Look at the Berk technology header! I think the OEM header is awesome enough, but if you really want a better cost per value for a new header, I'd suggest the Berk piece as its a j's clone without the price
Quick Reply: TURBO OR S/C EXHAUST QUESTION
