TURBO OR S/C EXHAUST QUESTION
Old 12-13-2014, 12:35 PM
beaudin223's Avatar
Default TURBO OR S/C EXHAUST QUESTION
ok so im looking to run S/C for around 430whp , im gonna change the test pipe for invidia one 70mm and i would to run 3 inch exhaust to the Y in the back and split to 2.5 inch , im gonna lose alot of power or i just should do 2.5 front to back sorry for my english
Old 12-13-2014, 06:11 PM
06S2k07Si's Avatar
This might be of some help...
https://www.s2ki.com/s2000/index.php...f=142&t=817368
Old 12-14-2014, 05:39 AM
weatyGT's Avatar
I was told 3" is best
Old 12-14-2014, 10:07 AM
Redline S2K's Avatar
A lot of the high horsepower SC guys don't run larger than 70mm. I think sideways runs stock and is over 500.
Old 12-14-2014, 05:58 PM
leoxle's Avatar
Yeah, I run a full 3" exhaust and apparently, 60-63mm is the best for superchargers according to this post https://www.s2ki.com/s2000/topic/710...erent-exhaust/
Old 12-15-2014, 07:46 AM
SeanGPW's Avatar
I was running the 3" Single Challenge exhaust but after reading and researching I have now switched back down to the 2.5" Tanabe
In the upcoming weeks going to switch to the Comptech exhaust to see how it sounds and go from there
Old 12-15-2014, 08:27 AM
beaudin223's Avatar
perfect thank you guys i will go 70 mm test pipe invidia with 3 inch split Y on the back to double 2.5 inch with magnaflow muffler sttrait gonna bee enough because 70 mm piping are really hard to find and the spiter too are hard to find , its alway 2 or 2.5 or 3 , its possible to find 70 mm piping ?
Old 12-15-2014, 08:56 AM
JUSTINTHECOASTIE's Avatar
If you are supercharged you want 60-63mm test pipe. 3" test pipes works great for turbo cars not so much supercharged cars.
Old 12-15-2014, 09:28 AM
beaudin223's Avatar
if i put a 70mm test pipe im gonna lose power ? its seem no sence ?
Old 12-15-2014, 09:51 AM
Originally Posted by JUSTINTHECOASTIE' timestamp='1418666211' post='23437780
[quote name='beaudin223' timestamp='1418664423' post='23437732']
[/quote]
Superchargers and turbos flow differently and have different exhaust velocity. You want your header, test pipe/cat, and exhaust to match. At the 430whp level, a 3" test pipe and exhaust is like pissing facing the wind, because at that power level it's overkill, less efficient and loud. You would ned to find the header that has the largest piping(I believe it's Berk), move to a 70mm test pipe, do your exhaust, and all the other mods to shoot for 500whp+ to make the larger exhaust worth while...
Edit: read upgrading to larger exhaust http://www.enginebasics.com/Engine%2...st%20Flow.html
Quick Reply: TURBO OR S/C EXHAUST QUESTION
