turbo built block
turbo built block
im having someone build my block because i had a scratch on the cylinder wall so so far we got darton sleeves how far could i go with just cp turbo pistons ,oem rods and bearings
There hasn't been one case of OEM rod failure, they can take a sh*t load of power..
I would however get a set of ARP rod bolts and replace the OEM ones while you are in there.
Yeah thats what i been reading alot of ppl making 500+ stock internals was thinking just going with 88mm cp low compression pistons but not sure was wondering what evryone else thinks
i have a built motor with AEBS sleeves, 89mm turbo pistons, peuter rods, ported head, oversized valves, 3mm headgasket, and a bunch of other goodies. make an offer if your interested. i have a complete turbo setup for very high hp goals, but will sell the long block seperate if there is enough intrest.
~jake
~jake
~jake
~jake
kinda dumb dontcha think?
Originally Posted by camuman,Jul 28 2010, 07:22 AM
the block was sleeved and then you put a 3mm hg also?
and whats a "turbo" piston?
or peuter rods?
I have benson sleeves acl bearings cp pistons 9.1to1 comp and pauter rods
just spend the extra few hundred bucks on rods and do it right. OEM are strong but heavy.
must have been oem compression assembled and he wanted to drop it for a shit-ton of boost? lol
either way, if youre building it, drop 600 extra for some forged rods. you're only gonna build it once, so build it totally right when you do it.
