TTS Race Supercharger kit build thread. Rotrex C38-92.
#52
Former Sponsor
Is that the max boost you can run with this kit? Pretty similar to the new kraftwerks kit if so. Those seem to put down around 410-420 bolt on with 93.
#53
I would imagine it is full boost as he said it is with no restrictor. Although i have a feeling the ignition timing is reduced to cap hp past 450 range on 93 octane (Speculation). Our tuner does not like to go much higher than 450 on pump with stock compression. I have no doubt in my mind that if a c38 91 was tuned at king and we did an overlay, the c38 92 would be worth the upgrade
#55
I could run one size smaller pulley. I have a 95mm on now to be safe...I could have run a 90mm but I didn't want to run the blower to its max. Probably only net me 2-3 more lbs of boost anyway.
#57
Originally Posted by Moddiction
Nice. What psi does your current pulley make now?
#60
Originally Posted by RAIN H8R
We the s2ki community demand an update! I heard someone dropped you off at King to pick up the car yesterday ;-)
443whp (61whp more) is quite a bit more than my old 382whp!!
