TTS Race Supercharger kit build thread. Rotrex C38-92.
Old 10-07-2021 | 12:48 PM
  #291
06S2k07Si's Avatar
So here are some photos of what can be used and what I used to install the Hybrid Racing transmission shifter springs. One deep well 12mm 1/4" drive socket one standard length 12mm 1/4" drive socket and one 12mm standard length 3/8" socket. Not all of these must be used but I showed what will work out of what I have. The long ratcheting 3/8" breaker bar is a Pittsburgh. The double headed 3/8" & 1/4" flex head ratchet is a Pittsburgh. The 1/4" long handle ratchet is from Astro Tools via Amazon.
https://www.harborfreight.com/3-8-ei...bar-66388.html
https://www.harborfreight.com/14-in-...het-67994.html
Amazon Amazon
The toughest part of this installation is after the removal of the top most screws, reinstalling them with Hondabond applied. Some minor contortions are required upon putting the screws back into the holes. Once re-inserted back into the hole you can let go of it to reposition your hand and possibly use a socket to drive them in with your fingers. Then re-torque.
Old 03-22-2022 | 05:43 PM
  #292
giorgosgrts's Avatar
Thats my dyno
BC Stage 2 Cams
Precision Intercooler
ID 1050x Injectors
Stock Header
70mm Single Js Racing exhaust with test pipe
Standard Fuel
At the current dyno it is with 21deg timing and we decreased it to 18deg to be more safe.
Old 03-28-2022 | 12:15 AM
  #293
pizzai69's Avatar
What model of rotrex ? pulley size ? boost level ?
Old 04-01-2022 | 12:29 PM
  #294
C38-92
95 Pulley
1 bar
pizzai69 (04-03-2022)
Old 08-28-2022 | 02:17 PM
  #295
06S2k07Si's Avatar
Latest edition... https://www.srpracing.com/pd-s2000.cfm These are beautiful! Super grippy and great feel. I finished them with an aluminum oxide wheel and they turned out great!
The following 4 users liked this post by 06S2k07Si:
dursteri (08-29-2022), Kyle (08-29-2022), Live Fast (08-30-2022), RolanTHUNDER (09-07-2022)
Old 08-29-2022 | 03:43 AM
  #296
Kyle's Avatar
WANT.
06S2k07Si (08-29-2022)
Old 09-07-2022 | 07:52 AM
  #297
RolanTHUNDER's Avatar
Originally Posted by Kyle
WANT.
X 2
Old 09-07-2022 | 07:53 AM
  #298
Originally Posted by giorgosgrts
Thats my dyno
BC Stage 2 Cams
ID 1050x Injectors
Stock Header
Standard Fuel
What octane is your standard fuel? 18 degrees of timing from what RPM and boost level?
Old 06-02-2023 | 05:30 PM
  #299
06S2k07Si's Avatar
Latest addition to the clan!
The following 2 users liked this post by 06S2k07Si:
Kyle (06-04-2023), pr.138 (06-02-2023)
Old 06-04-2023 | 07:14 AM
  #300
Kyle's Avatar
Congrats, Brian! An excellent counterpart to your beast!
06S2k07Si (06-04-2023)
