TTS Race Supercharger kit build thread. Rotrex C38-92.
#132
...and still more...
Upgraded APR fasteners fuse box
Upgraded APR fasteners fuse box 2
Upgraded APR fasteners master cylinder vacuum line bracket
Upgraded APR fasteners EPS and relay/cruise control bracket
Upgraded APR fasteners cruise control
Upgraded APR fasteners radiator fan
Upgraded APR fasteners catch can bracket
Changed to black oil cap, battery tiedown and valve cover washers
#134
Thank you for the kind words.
Sorry no updates.
I've been struggling with an illness for just over 6 months (started the first week in March) and have put this project on hold due to this. I've spent just north of $4500 out of pocket trying to get well. As I am currently better (for just over two weeks currently) than I've been all summer, I may possibly still have a long road to recovery. If things go well for me I would like to try continuing with this project next spring.
Thanks all,
Brian
Sorry no updates.
Thanks all,
Brian
#136
...so it's been an interesting and difficult year and the following has been too long in the making but it's finally here.
2017 Updates...
Added an Innovate ECB-1 quad display gauge ECB-1 (BOOST) Ethanol Content & Air/Fuel Ratio Gauge
Added SOS E85 sensor kit for reading ethanol percentage with Innovate gauge https://www.scienceofspeed.com/index...el-system.html
Autometer S2000 A-pillar gauge pod 22443
Fuel pump relay change to 60/80amp relay due to SOS kit relay socket beginning to melt.
Upgraded relay socket to 11ga main wires and 15ga trigger wires.
Upgraded fuel pump from AEM 320 E85 to Walbro 450
Upgraded fuel injectors from ID1000’s to ID1300X’s https://moddiction.com/injector-dyna...i-1956416.aspx
Added toggle switch to bypass relay to use to purge fuel system
Added a Jiffy-tite connector to the fuel rail for fuel purge purposes https://www.pegasusautoracing.com/gr...ID=JIFFHOSEEND
Reworked catch can setup to a dual can for better breathing https://www.ebay.com/itm/Cylinder-Al...53.m2749.l2649
More details to come.
Scheduled to be on the dyno November 2 & 3 for a complete 93 octane tune and a complete E85 tune.
Results to follow soon!
Many thanks to RAINH8R for assistance with all of the above.
2017 Updates...
#137
Sometime in the last year or so the Dynojet software has been upgraded and it appears as though the calculations for horsepower and torque have changed a bit (not sure what exactly). My previous dyno of about 443whp is now reading 439whp in the new software both with the SAE correction factor.
The changes from the previous 2014 dyno to the current one are as follows:
Walbro 450lph fuel pump and relay/relay socket upgrade (shouldn't have made much of a difference as I wasn't out of fuel on the previous AEM 320 E85 pump)
ID1300X fuel injectors (shouldn't have made much of a difference either changing from ID1000’s as I wasn't out of duty cycle)
Hot side intercooler piping increase in diameter from original TTS 2.5” to newly modified and better flowing 2.75”
Cold side piping diameter increase and complete reroute from original TTS 2.5” that eventually changed to 3” to just before the throttle body and now to full 3” from intercooler to throttle body and considerably less flow restricted piping path to outside drivers side frame rail and including reworking of both side intercooler tanks.
So the preliminary results are looking quite surprisingly good! Tuning is not complete yet but the increase so far is surprising. I picked up everywhere starting at about 3000pm on up. Increases in torque from 20lbft to almost 32lbft! We'll see where it'll be soon. This is all on 93 octane gasoline! We have not started E85 yet!
We're still trying to figure out the reason for the cap around 450whp from about 7300rpm to 8500rpm. It might either be the limit of 93 octane in this setup or perhaps some other flow restriction (maybe the 60mm exhaust is finally limiting me beyond 450whp). We're planning to remove the exhaust from the test pipe back to see.
#138
Dyno tuning has been completed. I will put up data and graphs later this weekend. The results are quite impressive! I need to overlay the graphs to get exact numbers but about 95+whp and 80+wtq increases on E85 from my previous dyno from 2014! Boost increased to 18.3psi!
Regarding the 450+whp limit from yesterday's 93 octane tune...that's it for 93. We tried to remove the air filter to see if it was a restriction and we lost 4whp by removing it. We then removed the exhaust from the test pipe back and there was no difference with or without the exhaust. So that's it for 93 octane on this car as it sits.
More to come...
More to come...
#139
Final results shown in STD correction factor. Ethanol content on this dyno is measuring at only E65. There may be more WHP available once the mixture in the tank gets to E75 - E80 or above. Spark plugs are still BKR8EIX but now gapped at .018" and still with OEM coils. 60psi base fuel pressure and 82% duty cycle on the ID1300X's.
Original unmodified TTS kit (on 93) vs TTS kit with new modifications (on 93) vs TTS kit with new modifications on E85 (measured at the time of this dyno at E65 actual)
