Transmission?
Old 03-28-2011, 10:03 AM
TerminatioN's Avatar
Default Transmission?
I've seen people say that after the Inline Pro Diff Kit (with DSS driveshaft + axles) and R200 that the next weak point is the transmission...
However I haven't seen much specifics about that. How much power/torque will the stock transmission hold? For how long? What's the weak point in it?
What are the options to upgrade to something stronger? Can you rebuild the OEM transmission and make it stronger somehow or is the only option to buy something aftermarket? Anything that won't break the bank but still get the job done?
Any and all info is appreciated.
Sorry if I missed something, but I searched a lot and didn't find much.
Thanks.
Old 03-28-2011, 10:08 AM
passmans2kny's Avatar
all options will break the bank and require custom fabrication
Old 03-28-2011, 10:21 AM
Round 3's Avatar
stock should hold around 4-500whp
Old 03-28-2011, 10:40 AM
Deception's Avatar
2 local guys I know destroyed 2nd gear @ 500whp in a few thousand miles. YMMV
Old 03-28-2011, 11:55 AM
it really depends how u drive it, if u mash gears your gonna break stuff, shift easy and your stuff should last, Im gonna try and run the stock one at 750hp, hopefully it hold up for a while
Old 03-28-2011, 01:13 PM
Sideways's Avatar
Max torque in second gear allows the long shaft to displace slightly and BOOM. Go easy on second gear. Power on in third.
Old 03-28-2011, 01:55 PM
noted
Old 03-28-2011, 04:27 PM
Thanks for the info guys. That sucks though. Almost seems pointless to upgrade the diff/axles now if the trans is gonna break anyways and I doubt I'll be able to upgrade that...
Ugh. Doubt I'll be able to afford any of them, but anyone have more info on specific options (and prices if possible)? Seems like PPG is the most common, but I know there has to be others out there...
Old 03-28-2011, 04:32 PM
Soul Coughing's Avatar
Rob! made 770ish whp on Evans' dyno and his tranny started making noise after a couple pulls on the dyno and then wouldn't engage in 2nd gear when at the track. Good luck, but don't 'bank' on your tranny lasting for more than a couple pulls; especially if you have traction.
Old 03-28-2011, 04:33 PM
Stick with 400-500whp and your tranny will last a while. I have been making that amount of power for the past 60k miles and the tranny is still in one piece.
Quick Reply: Transmission?
