torque specs for turbo install
Can someone help me out with some info.. In the process of putting my turbo back on the car with new revhard manifold. I had to take a lot of things apart due to clearance issues.
Precision 5857 turbo, rev hard cast log mani
What are the torque specs for...
-4 bolts that go from turbo inlet to manifold (im using stage 8 bolts for this)
-the 6 bolts that hold the center section to the turbine housing
-ARP manifold studs & the nuts
- 5 downpipe flange bolts
thanks in advance
thanks in advance
thanks in advance
thanks in advance
Originally Posted by JuicedS2K,Jun 23 2010, 11:29 AM
I just bolted my 5857 up, i just tightened everything, then tightened again after i few heat cycles, just make them tight man, there is no way of getting a torque wrench on all the manifold studs anyway, your gonna have to get in there with a wrench for some of them.
Good thing I have skinny arms, it help when contorting in the engine bay
Hows the clearance on the 5857 with the revhard manifold? How close is it to the frame rail? Can anybody post up a pic of their setup and what oil filter relocation you guys are using with it?
Im running the canton oil relocator, its a very tight fit. I need to grind it down more because the shop that installed did not, it was touching the turbo when everything was together
S2kserry
08-31-2014 06:43 PM
