Tips for the Track (1/4)
Old 09-08-2011, 08:18 AM
  #31
S20004ME_PDX's Avatar
I can appreciate what all the drag racing "vets" are saying, but I don't think there's anything wrong with your approach at all Joey.
I think there's nothing wrong with going out there once or twice just to get to know your surroundings at the track. Get a feel on how your adrenaline affects you and your driving when you line up at the tree, and methodically get more and more aggressive after each pass and watch yourself improve until you hit that wall where you know you need to launch and get better tires.
Granted, I'm running a GT30R on 14psi so I'm not putting down the same number as you, but since I don't have drag tires yet, I didn't do burnouts or launch my car. But I still had a ton of fun, I ran pretty consistent high 12's around 118mph, and now I look forward to getting a set of drag tries and see how I do the next time I'm there. The bonus is that I will be doing it with a lot less nervs.
My only advice for you would be learn to slip the clutch, it would be your best friend coming off the line to avoid any wheel hop.
Again, nothing wrong with doing things in stages, to some people its more fun that way.
Old 09-08-2011, 11:35 AM
  #32
camuman's Avatar
not everyone goes to the track to nail the best possible time. some of us go to just have fun, and see what the car can do with us driving it.
dude, go and have fun. be careful, stay safe.
i agree your tires are not ideal, remember you make serious power, and a typical street tire just wont hold it. do you spin in 1,2,3 or 4 gear flooring it on the street? if so they are not good enough tires.
boost by speed helps, but tires that are not up to the task will just hurt your overall trap.
when i go to track, i rev to 5ish, slip the clutch till it grabs while feeding throttle. its not balls out but it gets me going. i dont slam gears either, not worth 1-3 tenths of a second to drop a trans/diff. F THAT.
go and have fun. honestly, if you run to the cars potential they will just kick your ass off the track anyways. truth is a 130 trap car with no cage may get a stern talking too.
my guess, being that your on a street tire and not familiar with the track, 12.5-13.5@120-125.
its not indicative of the cars performance, but rather your ability to get it moving from a stop.
good luck and have fun. when it cools off here i plan to go break, err run my heap at the track as well.
Old 09-08-2011, 11:40 AM
  #33
ArchAngel2K's Avatar
R200 DIFF KIT!!!! FTW
Old 09-12-2011, 06:49 PM
  #34
o'malley_808's Avatar
Originally Posted by RealStreet
Stiff sidewall tire = wheelhop
wheelhop = diff fail.
Definitely get some drag radials for the track.
^^THIS^^
Broke the pinion gear on my diff on Hoosier radial rain tires (sticky as balls tire, Hard sidewall)
I didnt even leave hard off the line and cracked every tooth on the pinion
I have my new M/T radials mounted on AP1 rears. I just have to order one more line lock to complete the setup and try again
John
Old 09-13-2011, 06:00 AM
  #35
passmans2kny's Avatar
can someone refer me m/t radials that fit on an ap2 rim?
Old 09-13-2011, 06:23 AM
  #36
camuman's Avatar
Buy some used ap1 rears. It's worth it for the better size available.
Old 09-13-2011, 03:58 PM
  #37
Euroflavor's Avatar
I cant believe you guys are all over his case OVER AND OVER. he clearly stated hes not all in it for the ET. he cares more about his MPH in the 1/4 and easing off the line will not affect the ending MPH to much. It will slightly but obviously no where near the ET change. Once he can establish a good MPH time he can compare his car to other types of cars that are out there in the world. especially if hes in the mood to do some roll racing or something because Roll vs. 1/4mile MPH is how to compare cars the easiest way in a real/keyboard simulation.
I say you go and just have fun and not break your car.
oh and ps..... Csi FTW! McCavity Cat out!
Old 09-13-2011, 05:03 PM
  #38
H2kBBAP2's Avatar
Let us know what you run Joey
Old 09-13-2011, 05:17 PM
  #39
GO-AUTOWORKS's Avatar
Originally Posted by spectacle
Originally Posted by JoeyBalls' timestamp='1315345096' post='20948582
I don't plan on launching the car, nor do I plan on slamming the gears, just looking for some other pointers...........
Then don't waste your time.
You're not going to run anything close to your potential if you go out there pussy footing around. Either go hard or don't go at all.
No tips and tricks in the world can make up for a scared driver.
Very true.
Have fun w. the car. GL with it.
FWIW You dont have to "bang" gears...just flat shift it and let it ride.
cesarortiz
02-23-2016 09:51 AM
MMisencik157
09-14-2012 10:26 AM
Jasonoff
05-26-2006 04:36 PM
vepas
08-24-2003 12:54 PM
Quick Reply: Tips for the Track (1/4)
