TiAL 50mm BOV on vortech aftercooler
is it possible to put a TiAL 50mm BOV on a Vortech Aftercooler with a greddy adapter flange? i found a thread stating that it might be an issue with fitment.
here is the greddy flange: http://www.atpturbo.com/mm5/merchant...egory_Code=BOV
also, which spring is recommended for use? on the manufacturer's site, it says -2psi for supercharged. i am pushing 13/14psi at 9k.
thanks in advance!
::updated with video and audio::
http://www.youtube.com/watch?v=mSDHfYKAeNU
thanks in advance!
If the adapter is too big you may need to have a flange welded on to the after cooler. It would help to enlarge the opening too.
I was able to squeeze a Mondo BOV in place of the original but it was tight.
[attachment=82294:IMG_0850.jpg]
https://www.s2ki.com/s2000/topic/112...m-with-tial-q/
Plenty of clearance over here. The only caveat is that you put the bolts through the adapter first and then start tightening them by hand. I don't have any surge and I'm running ~24psi.
which spring are you using to support the 24psi? do you have any photos of your setup as of right now?
::update::
if anyone is trying to do the same by using a TiAL BOV on a vortech aftercooler, atpturbo.com sells their BOV with different flanges, including the greddy flange and different springs for different applications already installed. just got mine today. going to install it in a few
if anyone is curious on how loud the tial q bov is, i have updated the OP with audio/video.
IMO it sounds cool and all, but drowns everything you hear, even when your windows are up. it doesn't help that my hood is vented either.
