Test on different exhaust !
Old 06-28-2009, 06:32 PM
  #51
ChuckV's Avatar
A bit premature, as I'm only THINKING about picking up another S to SC, but if I go that route, I'd most likely go with J's or T1R headers, and then the T1R 63mm cat back, or the J's 60mm unit.
This thread got me thinking, I wonder if it'd be worth talking to Hytech to have them figure out what the ideal setup would be for a supercharged F22/F20 aiming to flow enough air to make ~380-420rwhp (as this seem to be the range most SC guys shoot for).
Old 06-28-2009, 07:55 PM
  #52
SFV_S2k's Avatar
Originally Posted by S20004ME_PDX,Jun 28 2009, 03:20 PM
Thank you. I was able to dig up that thread awhile back, and was hoping you have a different one.
So out of all the cooling mod's you've done with your setup, which one did you feel that was the most beneficial? So far, I have the Hondata IMG, t-stat, fan switch, and higher pressure rad. cap from spoons, and vented hood. But I'm still not happy with my intake temperature just after a few pulls, so I'm trying to see what step to take next aside from going water/meth.
My hood is vented and I took out the A/C. that helped out a little on the cooling side.
Im under the same cloud as u and others with the intake temps at 100's going up to 120-130's when I lay on it.
I will be tuning the AEM water/meth soon so I will let you and the other guys know what is the outcome.
I will also try to see what is the best water/meth ratio 50-50 60-40 40-60 ???
*On a side note, I did notice a significant change when I installed the skunk 70mm TB. My intake temps decreased my about 6-8 degrees.
***I didnt have any luck with the Hondata gasket
It started leaking boost ..
Old 06-28-2009, 07:56 PM
  #53
SFV_S2k's Avatar
Originally Posted by Riceboi,Jun 28 2009, 04:20 PM
leo why don't you be the tie breaker guy lol
Dyno with your 70mm and then with stock exhaust.
That would be great !!!
tuning gets a little expensive
Old 06-28-2009, 08:06 PM
  #54
SFV_S2k's Avatar
That would be a great idea!
I'm glad to have started this topic so people would build on it !!!!
Please share ur future results so that we might understand more our sc s2000's
Cheers !!!
Old 06-28-2009, 11:34 PM
  #55
Sarek's Avatar
good stuff omar!
Old 06-29-2009, 01:45 AM
  #56
QuagmireS2k's Avatar
Hey Omar let me borrow the J's 70rr. So i can do some test with my KW kit.
Old 06-29-2009, 08:07 AM
  #57
SFV_S2k's Avatar
I sold it
Old 06-29-2009, 08:56 AM
  #58
leo520's Avatar
my tuner told me, he have it tun twice with a different exhaust at the same day, so i will have to make another apoinment for the different exhaust tuning..
so i don't see the point spending thousands of dollars just to find out which is better....
Old 06-29-2009, 09:46 AM
  #59
Sportster's Avatar
this is blowing my mind... I actually did a lot of work and spend $$$$ in setting up a 70mm exhaust system from header, to cat and catback single... all this for nothing? and not only for nothing but actually for less!!!
Thanks for posting this info...
Old 06-29-2009, 10:41 AM
  #60
Riceboi's Avatar
well I think this applies to superchargers only.
Quick Reply: Test on different exhaust !
