Tapping factory fuel rail for pressure gauge
Old 02-10-2009, 06:38 PM
skool u's Avatar
Default Tapping factory fuel rail for pressure gauge
Hey lads,
just wondering if anyone has added a fuel pressure gauge to his "factory" fuel rail. I've seen a small plug there, but is this threaded or will I need to have it threaded? Also, will it just screw out or will I have to drill it out?
Cheers boys.
Old 02-10-2009, 06:42 PM
John_Z's Avatar
On my old fuel rail I had the top drilled/tapped
Old 02-10-2009, 06:50 PM
ATOice's Avatar
^^ Mine is done the same....
Old 02-10-2009, 06:55 PM
dsddcd's Avatar
I am doing mine later this week.
Old 02-10-2009, 06:56 PM
2big4aS2000's Avatar
i have done several, i drill out brass end plug, tap it and use a 1/4 to 1/8 npt plug to screw the guage on the end.
Old 02-10-2009, 06:58 PM
skool u's Avatar
Easy enough now one last question. With regards to the gauge, what gauge would you recommend that would be able to withstand Canada's -30 and colder climate every now and then? What is that gauge filled with and what is it's rating for temperature?
Old 02-10-2009, 07:19 PM
ChefJ's Avatar
CAn you screw the 1/8th" npt directly into the fuel rail or do you need to "tap" it the right size or get an adaptor??
Old 02-10-2009, 07:22 PM
dsddcd's Avatar
I have been looking for a Schrader Valve fitting so I can screw on a gauge for testing only like many OEM's.
Old 02-10-2009, 07:26 PM
ChefJ's Avatar
like this??
http://www.airridefittings.com/store/index...&products_id=24
Old 02-10-2009, 10:19 PM
Sideways's Avatar
That is the easiest way to do it.
Use teflon tape on the threads.
The gauges with the liquid are oil filled and should not freeze. The Marshall brand is very inexpensive and can be purchased for less than $20 on the internet.
The fuel rail will polish up readily too. Yes, John, it does make it lighter.
Quick Reply: Tapping factory fuel rail for pressure gauge
