tappin oil pan
Talking to you people is useless. It gets so frustrating when people regurgitate what they have heard instead of having actual proof themselves.
Its a straight shot from the turbo to the oil drain plug and if yo useen mine you would understand.
^ what is the difference if it is tapped at the oil pan drain, above the drain or in the girdle?
Mine is in the lowest spot of the pan that can be tapped. Perfect for flow.
I had the most straight viertical downward path to the oil pan and I still had problems.
So personally I will always tap above oil leve.
Japmuscle
05-31-2013 08:47 AM
