Symptoms of a failing alternator?
For past week my Gauges have been flickering like crazy at idle and idle gets rough now. As I watch AFR gauge it starts to fluctuate too much, but it does it only when flickering gets really bad. SO WEIRD.
I wonder about this myself. My dash lights slightly flicker and wonder if its battery or alternator. When dash starts to flicker i get a bad idle.
Sent from my Galaxy S II using Tapatalk
I've been reading about this on the other sections and it could possibly be the rectifier inside of the alternator. A bad diode(?) in the rectifier would cause the flickering. I have no idea about the technical aspect of this, it's just what I have read and others have agreed on. I currently have a used alternator en route to me with low miles so that I can swap out the rectifiers. Brand new I believe it is about $160 from HandA parts.
Make sure all your major grounds are clean and tight.
When an alternator fails they usually just fail, your battery light comes on the dash and the car will just run off the battery, well, until it can't anymore and then you're stuck.
