Supra V160 Getrag Conversion
#71
It hasn't let go yet and is running great. It's the stock trans I'm worried about and this conversion LJ and FullBlown has come up with will relieve that stress once I am able to get it.
#74
How many guys will be interested in a single disc clutch for this conversion? It would be a custom flywheel with a supra pull style clutch. Here's our options so far for clutches
- CM Twin Disc with custom adapters,Hydraulic Bearing and stainless lines (rated to 1000HP+) $2295
- CM Single Disc with custom Flywheel and utilizes all stock Supra components (rated to 700hp-800hp) $1295
I will have the price for the adapter plate with all hardware, shifter bracket, and rear mount hopefully by Fri.
#76
I would be interested in single as well, I am planning to try producing just under 700WHP with an intense power band, basically max out a VERY streetable turbo.. I wont need anything more than that.. what would the torque rating be?
#77
It will easily hold 600ft lbs. Stock s2k clutches are roughly 8 inches. We are going to a 10" clutch kit with more clamping load. There will be more options for different disc and pressure plates.
#80
![](https://staticssl.ibsrv.net/autocomm/Content/S2Ki/milestonestars-5yr.png)
deff in for the much needed twin disc..also trying to get rid of my r200 for one of your kits
if anyone is interested in a practically new r200 kit with a diff 1000whp axles hubs aluminum ds pm me
thanx
thanx
