Supra V160 Getrag Conversion
Old 09-22-2014, 07:57 PM
  #781
neeman77's Avatar
Hey buddy, you have to put the clutch on the input shaft then lift it all in together. You tighten the pressure plate bolts through the access hole once the tranny is bolted up. Also have to notch the v160 case for the starter. Call full blown and they will email you instructions.
Old 09-23-2014, 02:17 PM
  #782
Former Sponsor
FullBlown's Avatar
Originally Posted by bottleboy
does anybody have the instalation instuctions for the v160 and the tool to line up the clutch i emailed fullblown last week no response ???
I am sorry that we missed the email. Instructions can be found on our site now. Let us know if you have any further questions.
http://fullblownmotorsports.com/car-...on/acura-honda
Old 09-23-2014, 02:30 PM
  #783
bottleboy's Avatar
thanks guys
Old 12-03-2014, 10:42 PM
  #784
honda freak's Avatar
guys am in the process of installing completted everything installed the tranny and the 8.8 diff with DSS axels and everything, but when i drive the car i hear a knocking sound dunno from where, please if anyone experince anything like that pleaes let me know.
other thing did anyone try to install a short sifter on the car , because as you can see the shifter is too long where it's hitting with the frame, but with a short shifter i think problem will be solved.
hope to hear from you guys
Old 12-04-2014, 08:42 PM
  #785
neeman77's Avatar
Your driveshaft is touching the nose mount for the differential, check that you installed enough washers. The stock shifter should fit perfectly with OEM tranny and engine mounts.
Old 01-26-2015, 12:16 PM
  #786
1SlowSi's Avatar
Its been a while since anyone has posted on this thread. Any new V160 users? Any additional thoughts and/or opinions on this setup? Anyone else install this and NOT experience all the loud noises?
Thanks.
Old 01-26-2015, 01:51 PM
  #787
Nelsonr31's Avatar
^^^^^^^^ X2 Looking for some insight and experience.
Old 01-27-2015, 04:53 AM
  #788
1SlowSi's Avatar
It seems as if everyone has steered away from it. Too much moolah!!
Old 01-27-2015, 08:11 AM
  #789
S2-Kai's Avatar
Hang in there guys (n gals), I'm still working on a custom 6 speed conversion using another getrag donor unit.
Old 01-27-2015, 09:00 AM
  #790
bottleboy's Avatar
if your to the point you need a v160 its because you already invested more than that in your engine and you waNT to use the power .
if your under 500Hp you dont need it, never dont ask for info just take care of what you got if your braking your s tranny under 500hp your just abusing it
Quick Reply: Supra V160 Getrag Conversion
