Supra V160 Getrag Conversion
#724
Originally Posted by p0staboy' timestamp='1355801944' post='22216594
anyone know if it's ok to start up my car with no fluid in the v160? I want to let the motor run since its bin sitting for a while i will keep my foot on the clutch so the tranny doesn't spin, if you're wondering the case is cracked so it wont hold fluid.
Sent from my DROID RAZR using Tapatalk 2
#725
Originally Posted by bobbyrandolph440' timestamp='1355817759' post='22216887
[quote name='p0staboy' timestamp='1355801944' post='22216594']
[/quote]
Tig weld and jb weld are world's apart.
#726
Hahahahaha. Dude just do yourself a favor and leave this forum....SMH
#727
[/quote]
Yes bro just take to any shop that tig welds have em weld it up use sum filler rod and your.good if your that worried about it have them weld a plate over crack to help reinforce it
#728
So I dropped my v160 the other day and I was surprised how easy it is to drop with the FB kit on it. All I really had to do was loosen the steering joint,remove downpipe then lower the subframe and start un-doing the bolts to the tranny. It literally took like 1.5-2.0 hours to do it and I was going really slow reading the shop manual. My question is when putting it back in do I have to take the clutch off and put it on the tranny then mount it to the motor or can I put the tranny in with the clutch on and just keep turning the prop flange till all the splines line up to get it in.
