Supra V160 Getrag Conversion
Old 07-05-2012, 09:23 PM
  #601
p0staboy's Avatar
Originally Posted by passmans2kny
I am getting nothing on the cluster, the speedo healer is seeing 12v from the o2 sensor that wasnt being used, I ran test mode on the speedo healer and got the t to flash when i put it in first gear indicating its wired correctly, I used 36500 as the calibration, then tried a few more ranging both ways with no luck so far, this was on jack stands with the tires just spinning, dont really know where to go from here, my buddy did the wiring and has the speedo healer going into the back of the aem, the toyota vss clip is spliced into the honda wiring the way the full blown diagram said to.. any help would be greatly appreciated, I wanna get this working so more people can do this easily in the future too
Where are you seeing the T when you put the SH into test mode? When in test mode your dash should go up to about 7mph then stay their for a few seconds then go back down to about 1. That's what happends when I put mine into test mode. T should show up on the SH itself and when it does show,the speed on your cluster will go up like I said. If your cluster doesn't change speed your SH is not wired up correctly. Also which wire is hooked up to your AEM? I didn't have to wire my SH into my AEM
Old 07-06-2012, 04:11 AM
  #602
passmans2kny's Avatar
Originally Posted by 99SH
I was browsing around the internet to see if I can find the frequency output from our VSS sensors. Assuming the values posted in the forums were correct, the s2k VSS is ~37.6 times faster relative to the v160. Try to set your calibration somewhere around 37 and see what happens.
ok so would that be 37000 or 00037?, or 00370?
Old 07-06-2012, 06:31 AM
  #603
99SH's Avatar
What is your calibration set to?
00037
Old 07-06-2012, 07:48 AM
  #604
CD7SirAccord's Avatar
00037
That would actually be 3.7%. For 37% you want 00370
Old 07-06-2012, 07:52 AM
  #605
99SH's Avatar
Originally Posted by CD7SirAccord
Originally Posted by 99SH' timestamp='1341585104' post='21838370
00037
Thanks. Hope the speedo issue gets corrected so we can all learn from this.
Old 07-06-2012, 08:02 AM
  #606
Originally Posted by CD7SirAccord' timestamp='1341589706' post='21838599
[quote name='99SH' timestamp='1341585104' post='21838370']
00037
[/quote]
Agreed, we'll eventually get this all figured out
Old 07-06-2012, 08:33 AM
  #607
p0staboy's Avatar
your SH is not wired up correctly. How do you currently have it wired up?
Old 07-06-2012, 08:42 AM
  #608
herecomesboost's Avatar
Keep it up, trailblazers!
Old 07-06-2012, 09:32 AM
  #609
p0staboy's Avatar
00037
Just tried this and it does not show any readings.
Old 07-06-2012, 09:33 AM
  #610
p0staboy's Avatar
Here is a test of the SH. Set the SH into test mode and this will appear on your dash. If you see this you will know your SH is wired properly
http://www.youtube.com/watch?v=NJOOw6NAtYA&feature=plcp
Quick Reply: Supra V160 Getrag Conversion
