Supra V160 Getrag Conversion
#361
To save the hassle of finding the OEM plug for the VSS from a junkyard or something, I've found the plug and wires here. They sell the wires individually, so you will need to order 3. Make sure you get them with the large seal.
VSS 3 Pin Plug:
http://store.driftmotion.com/static/...nector3pin.php
You will also need the 090 II style terminals with large wire seals found here:
http://store.driftmotion.com/static/...iiterminal.php
I'm also wondering if it would be possible to maybe use the Modifry Yellow Jacket Speedometer Calibrator. I'm wondering if the issue isn't necessarily the difference between the supplied power to the sensor, but rather the pulses given off by the VSS. Or if voltage does need to be regulated, if you might be able to use some sort of potentiometer.
I'm definitely not a sparky, and I might just be talking out of my ass, but as soon as I get all the stuff installed and a solution hasn't been found, I'll definitely be working on it with a co-worker who is. lol
VSS 3 Pin Plug:
#363
I ordered one today from a 98, 30k miles with shifter shipped from vegas.
(thanks again to gsx2004 by the way for that)
Damn i was happy but now you made me depressed because
that is a price you will never see unless theres something wrong with it.
good for you!
#365
Originally Posted by p0staboy' timestamp='1331251133' post='21491386
picked up a getrag v160 today at a local importer for $2800CND tax in. What a f@#king steal so happy.
I ordered one today from a 98, 30k miles with shifter for shipped, from vegas.
good for you!
#367
Get an actual speedohealer. -99% to +9999% correction and 3-19V working range. The Modifry box will only reduce pulses, if you need more pulses you'll be out of luck.
#368
EDIT: nevermind, I'm on my phone and just found the universal harness option.
