Supra V160 Getrag Conversion
#352
and as spectacle mentioned, what about electronics such as with the speedo for drive-by wire with flashpro like mine?
whats the issues you see that can happen? anyone?
#355
yea that seems to be the big mystery after doing my research too... It is the one problem i know that will have to be addressed. what about LJ? Is his working?
#356
The cluster uses the VSS for speedo (duh) but it also for EPS, soft top failsafe, intermittent wipers and probably VSA in your case. Whether any of this matters is going to come down to how different the pulse count is from stock.
I'll be able to fix the issue in my case when the next kmanager is released because Kpro has speedo correction built in, just not enough correction for my setup. I couldn't find an equivalent in the Flashpro software, but I just looked at Flashpro software for the first time, so correct me if I missed it. You can use a speedohealer, which is what I did in the mean time, but gear calculation may be incorrect if you need it for boost by gear.
Edit: Ok, found speedo correction in Flashpro. You still may want a speedohealer depending how much correction you need because the cluster is not fed from the ECU. The signal is split first and sent independently to the ECU and the cluster.
#357
Yes you will need to convert to 12v and use a speedohealer. I dont know how close you can get it because we have not tried it yet. I dont think the S2K cluster gets it's signal from the ecu, I could be wrong though. I believe the dash gets the signal direct from the sensor but again I could be wrong since we have not gotten a chance to mess around with it much. I know there's a solution for sure, I just haven't gotten the opportunity to get to it yet.
#359
I will definitely report my experiences when the time comes for my conversion. I would like to hear others' experience with this as well once the time comes
#360
Looking in the helm it looks to me like it still splits first, but I don't want to say y/n based on my half-assed knowledge
