Supercharged and BOV need help
Hi guys,
I've bought a PLM intercooler for my comptech supercharger setup which will be running low boost (4.25 pulley). The piping has a HKS BOV mount on it, my question is will the BOV that comes with the comptech fit this? If not should I get an adaptor or just buy a HKS BOV or something? I have no idea what to buy or what to do. I'm not bothered about the sound, if I can blank it I will.
Any advice appreciated
Thanks
Thanks
PM me about the HKS - i'll see if its in budget.
Is there a standard flange name for the comptech flange or is it just a 1" port? Does it plumb back into the air intake elbow?
cheers
cheers
The comptech bypass valve doesn't mount like the greddy flange on your piping. It has a 1" hose that runs to the bypass valve on the boost side and is routed back into the intake side via another 1" hose, or if you prefer can be vented to atmosphere.
Cheers -
So do i need something like this?
http://www.ebay.co.uk/itm/25mm-1-HKS...item4ad6001ec3
Then I can use the 1 inch hoses?
You have the right idea but those are all to mount different blow off valves. You basically just need a piece of 1" aluminum piping long enough to get a hose and clamp on and have it welded on. You may be able to do that over the existing flange, would have to see it. Perhaps the easiest solution would be to buy the correct bov for the flange you already have.
