suggestions for high flow oil pump
Old 07-30-2010, 09:54 AM
ChefJ's Avatar
Originally Posted by Irishflame27,Jul 30 2010, 09:52 AM
who built the motor?
a guy named Mike Laskey out of Anaheim CA. from what I have heard he does pretty good work.
Old 07-30-2010, 10:37 AM
Irishflame27's Avatar
for someone that is seeking help, you sure come back with very sarcastic remarks... goodluck TRY AGAIN
Old 07-30-2010, 11:28 AM
ChefJ's Avatar
where is the sarcasm?? Besides I asked about an oil pump not other suggestions to beat around the bush.
Old 07-30-2010, 11:44 AM
camuman's Avatar
guys run the stock oil pump into the 800's. yours not holding pressure implies something else is wrong.
thats what sucks.
Old 07-30-2010, 11:50 AM
ChefJ's Avatar
thats what sucks.
its possible that the cam journals may have issues I will be checking into that tonight. I had the same issues a few years ago with oil pressure so I am going to change the pump out anyway. Stock pump it is then. I understand the pump doesn't actually produce the pressure just pumps the oil and the pressure is formed from the clearances and whatnot. I just don't think its flowing as well as it should be.
Old 07-30-2010, 11:53 AM
this just seemed like a very condesending and sarcastic reply
sorry if i mis-took it
Old 07-30-2010, 11:55 AM
ChefJ's Avatar
all good. Not everyone knows of Laskey. Or atleast I assume that not everyone does.
i have a low milage oil pump that you can have it you pay shipping, maybe has 40k on it, i would disassemble it tho and check clearences
Old 07-30-2010, 11:59 AM
ChefJ's Avatar
that would be amazing. If it came out of a running vehicle it has to be as good or better then the one I currently have. pm me and I can paypal you or make arrangements.
Old 07-30-2010, 07:23 PM
Spoolin's Avatar
You could try switching to -8 oil lines on the relocation kit and also make sure youre using a -3 feed on the turbo and at least a -8 return to the girdle or fron drivers side of the oil pan. I've been using -8 relocation lines for 7 years with no problems. Ultimate racing also uses -8 size lines on their kit, which is what I have.
Also, what oil filter are you using? Sometimes a cheap oil filter may cause this. I recommend usng the 15400-PCX-004 OEM s2k oil filter.
Quick Reply: suggestions for high flow oil pump
