Strong fuel smell. Gas tank under high pressure. Burbling noise from the gas tank.
Gas tank under high pressure. Gugle noise from the gas tank. Strong fuel smell.
One hour into the drive I smelled gas. Once in the city and in traffic gas smell got even worse, so I pulled over to make sure it wasn't my injectors, which thankfully it wasn't since my engine bay is Lava Hot.
I checked my gas cap and it was hissing which was weird, so I take it off and due to high pressure it hissed for solid 4 seconds and then just continued to make bubbling noise, and still is like 20min later.
I unplugged the battery and left the car disconnected. Also, I watched my AIT, coolant temps, AFR and no CEL. Car ran fine, just reeked of gas.
What the F....??? (Oh I'd like to add that the cap is only a year old.)
EVAP canister may be full if the cap doesn't fix it.
I never fixed it, as it never happened again with OEM ECU since however I am on a stand-alone now (AEM Infinity) and I get a solid whiff of fuel smell from time to time now. Annoying.
Optikal
01-28-2005 09:53 AM
