Specs on turbo
Specs on turbo
Does anyone know the specs on this turbo? Who makes it? How much power can it handle? Is it a good turbo?Bad turbo? Why is it bad if it is? Thanks guys.
https://www.s2ki.com/forums/index.php?act=m...d=si&img=310308
looks to me like a GT35
It can handle all the power you need. (rated up to 600hp)
It will spool at around 4500 rpm since it is not ball bearing
If you use it with the inlinePRO manifold, you will need to cut your chasis
If you want to keep your car at 400whp max, then I say get the GT30R. I have Precision SC61 which is almost the same size with GT35 just a tad bigger. I'm at 451whp with no problems
What else do you need to know?
Have them measure the compressor and turbine wheels. That should tell you for sure.
Tim
Tim
Batikan, is that just a guess or do you know its a gt35 turbo? I bought this turbo kit off rick bailey and it is a inlinepro kit. How much boost do you think my stock motor can handle with this set up? No headgasket.
I really want to run 9.5 or 10 psi, but am scared its going to blow my motor. I just want it running safely then put a gasket on down the road.
Timg, how do I get the compressor and turbine wheels measured?
Thanks again guys for the reply
You can run 9.5 - 10 psi on stock motor. Just make sure you get an EMS and find a good tuner
