Sparkplugs
Old 05-11-2009, 11:21 PM
roi
roi's Avatar
Default Sparkplugs
Is anyone using this NGK BKR8EIX ???
I need one to support about 600WHP
Thanks
Old 05-12-2009, 05:18 AM
TelosHedge's Avatar
i'm using the 8's - should be just fine for your application.
Old 05-12-2009, 05:48 AM
siadam's Avatar
Same here.
Old 05-12-2009, 06:10 AM
neeman77's Avatar
leave the preset gap for that HP level?
Old 05-12-2009, 11:59 AM
s2000Junky's Avatar
Wouldnt two steps colder be wise for 600whp? I use this plug in my 350whp application
Old 05-12-2009, 10:26 PM
roi
roi's Avatar
When you say 8's do you use these BKR8EIX ???
Old 05-13-2009, 04:55 AM
s2kswe's Avatar
I am 99% sure the answer is yes.
The NGK iridiums are common among FI s2000's on these boards it seems. I am using them myself as well.
Last year when I did my first build, I was scouting around for plugs since I didn't know what to get, I didn't even know what alternatives there were. Out of luck I found the bkr8eix plugs. They work great. ~350whp setups.
For higher hp setups 9's could be used I think.
Old 05-13-2009, 07:48 AM
s2000Junky's Avatar
Yeah I use the BKR8EIX-2668. 350whp
Depends on the set up though, I supose these plugs could work well on a 500-600whp set up if your using water/meth injection or some other high octane race fuel. Otherwise I would think 9's would be a safer bet.
Old 05-13-2009, 09:33 AM
AndyFloyd's Avatar
are people gapping them down or keeping factory gap? Thanks
Old 05-13-2009, 09:59 AM
Soul Coughing's Avatar
i go as wide as i can run without misfires. Each car seems to react differently.
Quick Reply: Sparkplugs
