spark plugs...
spark plugs...
I have searched and there are just too many different plugs that people are using. I am going to be running a maximum of 12psi on my pfab/ custom turbo setup...it has a log manifold so im guessing 400whp will be the maximum that im gonna get out of it. I was thinking a NGK V-Power copper plug thats 2 heat ranges colder, what plugs are you guys using? THANKS!!!
my Greddy plugs are $80.00..............way toooooo much
These were recommended to me, by Courage.
http://www.sparkplugs.com/more_info.asp?AAIA=&pid=3252
They ARE SO MUCH cheaper, only thing is they are Copper, I dont mind changing them more often (every oil change), but would I be better off sticking with Irdiums, or do they just last longer?
I will be getting tuned wit the METH in NOV so I will have my plugs in by then
Get the NGK BKR8EIX.
NGK Iridium plug, resistor type, one heat range colder than stock (8).
They cost around 7-8 dollars each and i use them and really like them.
Whatever you do dont get Denso iridiums, they are horrible.
But I hope you hit 400!
