spark plug gapping
Old 05-11-2006, 12:26 PM
Spoolin's Avatar
I run the NGK BKR7E(very good plug for forced induction) with a gap of .028", am at 6.2 psi right now conservatively tuned, and put down 331 whp and 217 lbft of tq.
I wouldn't gap any more than .032" on any forced induction and risk miss firing if I were you.
Old 05-11-2006, 01:10 PM
CaptKirk's Avatar
I have the NGK BCPR7ES gapped at .032" and car seems to be running smooth and strong (when running )
Old 05-11-2006, 01:41 PM
Sideways's Avatar
Some bad info in this thread.
Originally Posted by robert112
you think a few misfires is going to cause dents in the s2k's forged pistons? s2k's have knock sensors anyway it'll automatically retard the timing.
This is coming from experience. I had a 12 second s13 and getting the right sized gap is important.
A gap to large will not cause pre-ignition and the knock sensor doesn't come into play.
Bad plugs or a gap to large for conditions causes misfire, a failure to ignite.
Proper gap is important with a supercharged S2000 and that is why the thread starter asked for experienced advice.
Old 05-11-2006, 02:23 PM
r_duff's Avatar
Originally Posted by 9kFever,May 11 2006, 12:18 PM
what are the NGK 7405 series? all my research pointed me towards the 7173 copper racing plugs...
they are the same a the 7173s, but 2 steps colder, not just 1. MY research says anything more than will get you 100 whp and up you should use 2 steps colder as a safely measure.
Old 05-11-2006, 02:35 PM
robert112's Avatar
sorry, it was late at night for me i was mistaken. yes your right a gap too large and your spark blows out. Does not cause a knock but rather a miss. other than that, you are agreeing with me.
Old 05-26-2006, 08:40 AM
gotswap's Avatar
Is this a colder plug?
Old 05-26-2006, 10:08 AM
Spoolin's Avatar
I believe they're 1 possibly 2 steps colder than the stock plugs.
Old 05-26-2006, 11:46 AM
gotswap's Avatar
Well the stock and plug that you use are both a 7 heat range?
Old 05-26-2006, 05:36 PM
Slows2k's Avatar
The stock Plugs are a heat range of 7. NGK plugs go colder as the # goes up.
7173's are 8's
7405's are 9's
The TAFC funny car I worked on used 10's.
Old 05-27-2006, 05:28 PM
XclusiveAutosports's Avatar
What do you guys think of 7405's with a gap of .032" with 7lbs of boost? This is what I thought was recommended, but everytime I read a FI spark plug thread I get different opinions.
Quick Reply: spark plug gapping
