I put together a chart, based on input from other members and some S2ki searching. If you see anything wrong please let me know. Also the "Gapped" column reflects the gap the plugs come with. If you use a different gap with a given plug, let me know. Other plugs can be added too.
-Thanks
OK the search function is working now. Looks like for FI the most common plug gap being used is .035", and some are using .030". Maybe .035" for up to 10psi boost or 330WHP, then .030" for >10psi or >330WHP?
