SOS TS Max Turbo Kit Build Thread
#74
It uses the stock mount. However, they supply a custom bracket that you replace the factory one with to get more clearance for the turbo. They include a custom heat shield for the mount.
Check out my first series of pictures. I posted one with the mount and heat sheild
Sent from my SCH-R970 using Tapatalk 2
#78
Man oh man it is very slow at work today. Tomorrow will be no different. I think Ill bring the installation instructions with me tomorrow. Here is what my garage looked like when I left this morning Sent from my SCH-R970 using Tapatalk 2
#79
Started working on the car today. Im addressing some leaks I had on the trans and oil pan(new/used f22 swap in the spring). Im having my local shop and tuner weld a bung on the top of the oil pan for an oil return. They have persuaded me to run a -10 turbo drain vs the -8 sos runs on the turbo and supercharger system.
Later today I will start installing some components such as the intercooler and some intercooler piping. It looks like I may need to remove my anti bumper steer steering rack spacer kit as it looks like the intercooler pipes go over the rack not under it. I still need to verify this.
