SOS TS Max Turbo Kit Build Thread
#361
For the sake of saving some pennies for now, I am sticking with my current setup. If the power curve changes and it keeps climbing to redline, I will then swap out my injectors and fuel pump to support more power.
#362
hi, been reading this thread for a couple months now.Its sad to see all this stuff the OP is going thru after spending a couple grands on this.
Got my car returned today. I have the GT3582r kit installed. The install was normal, with no problems encountered, there was no need to improvise in any step of the installation. This kit looks and fits like if it was Honda Oem. To me thats a plus.
Opening build thread in coming days.. few days later some dyno numbers.
#363
Geeze, need to up the fuel system because it will max out at 500whp. How much power are you looking to make on this kit?
I'm beginning to just look at this kit as the Greddy 2.0 turbo kit. It's the super fast response that everyone loves about the greddy kit, however it makes a respectable amount of power as well.
I think the problem was that this kit was just SOOO overhyped from the beginning. Everyone wanted this kit to spool full boost at 3500rpms and also make 500whp. You can't have your cake and eat it too, even if its a 6 thousand dollar cake.
#365
If your power curve really bugs you, run 12psi until 7krpms and then ramp it up to 14psi at redline which will flatten out your torque curve and keep your power increasing up to redline. Of course you'll be giving up mid-range torque and power, but it'll give you the power curve you desire.
Just for reference, some other cars with flat power curves. They sized the turbos for max driveability providing the most area under the curve and boat loads of mid-range. Of course, if that's not your preference, then that's not your preference.
BMW M5, twin turbo V8, flat power from ~5700-7200
AMG, twin turbo V8, flat power from 4500-6500
#366
After talking to chris and s2000442 on the phone today I think I have decided to give e85 a try. I have a walbro 255 and id1000s so I think that shouod give me enough space to go more aggressive on the ignition map for my 10 and 15psi map.
I have a feeling I will still hit a flat line but just closer to redline.
Thoughts?
Sent from my Samsung Galaxy S4
Thoughts?
#368
Originally Posted by spdracerut
If you keep your boost curve the same, I expect the torque/power curve to remain the same. With E85, it should just shift your torque curve straight up and result in about another 50whp.
#369
#370
Just an observation, on EVOs I see the stock exhaust housing aftermarket turbos pretty much always have to run at higher pressure ratios to make power. In the SOS kit case it seems like a fair compromise for the packaging of the kit.
Complete divided setups are more difficult to "nail down" the optimal than undivided. For the F20c series it seems longer equal length manifolds and full sized T4 housings seem to do it--at least that's what I have seen. Those blow all the packaging of the SOS kit away however...
