SOS TS Max Turbo Kit Build Thread
Old 10-13-2013, 06:11 PM
  #241
jzz30's Avatar
A car that is slightly lagier would be easier to power out of a corner I would assume. But for either way responsive power is great and even better for the street. I've driven an evo and an s14 that produce about 400 ftlbs by 4000 rpm. Its really fun the evo did it closer to 3500rpm it was like driving a big v8
jzz30 is offline
Old 10-14-2013, 03:07 AM
  #242
timg's Avatar
IMO, lag coming out of a corner is not what you want. I had a GT3076R that spooled very fast. Coming out of a corner, it was nothing but progressive. Not having any significant lag meant that I got exactly the power I wanted when I wanted it.
Tim
timg is offline
Old 10-14-2013, 06:45 AM
  #243
Jmays2k's Avatar
Tim
Jmays2k is offline
Old 10-14-2013, 06:29 PM
  #244
s2000Junky's Avatar
Tim
Right, so like a Supercharger
s2000Junky is offline
Old 10-15-2013, 09:13 AM
  #245
Former Sponsor
ScienceofSpeed's Avatar
Congrats Dustin, the results look awesome!
Regarding the power curve, remember that this is a 35R turbine, but a much smaller compressor side (76mm) than the normal compressor you see on a 35R (82mm). I believe Dustin specifically chose this setup to get the best spool response with a setup capable of ~200 BHP gain on 93 octane.
A 200+ BHP gain on 93 octane out of a 4 cyl engine with killer boost response is awesome !
The results are actually out performing the compressor map for this turbo:
ScienceofSpeed is offline
Old 10-15-2013, 10:05 AM
  #246
Former Sponsor
Originally Posted by baZurk
Originally Posted by camuman' timestamp='1381516715' post='22823110
I think low boost creeped
Yea that too. The graph shows the low boost creeping to 12-13psi.
The system does not creep. This is likely wastegate boost control solenoid duty added by the tuner, which is normal on a smaller compressor turbocharger system.
Old 10-15-2013, 10:32 AM
  #247
boostaddict712's Avatar
Originally Posted by RAIN H8R
I also seem to hear a whistle at certain speeds. Perhaps the intercooler is to blame, but I have yet to test my theory. I also noticed girgling near the turbo after shutting the car off. It appears water is moving around. I doubt there is air in the system though
Sent from my Samsung Galaxy S4
No whistling sounds here. What speed are your referring to? Although I the girgling sound near the turbo after shutting her off is there for me as well.
Do you have a wire dangling, which makes contact with the intake pipe from the turbo? About to tape mine up since it gets pretty hot there.
boostaddict712 is offline
Old 10-16-2013, 09:52 PM
  #248
spdracerut's Avatar
That's the water cooled center housing on the turbo doing its job. The coolant boils and siphons fresh coolant through the turbo to keep on cooling it when the car is shut off. This is to prevent oil coking.
http://www.turbobygarrett.com/turbob...er_Cooling.pdf
spdracerut is offline
Old 10-17-2013, 04:40 AM
  #249
CoolGuy094's Avatar
What an excellent document, thank you for sharing. I love it when manufacturers take the time to write articles like that to educate the general public on their product.
CoolGuy094 is offline
Old 10-17-2013, 05:11 AM
  #250
beaudin223's Avatar
but this kit is still weird at 7k stop to climb , with more boos or with E85 thsi can climb up to 9k ?
beaudin223 is offline
Quick Reply: SOS TS Max Turbo Kit Build Thread
