SOS TS Max Turbo Kit Build Thread
#221
"Timing was 15* on low boost roughly 10 psi. The timing on the high boost was 13-14* at 14.5 psi. Target A/F was 11.9:1 on both runs."
Any more timing and it would detonate
#222
could the minimal difference be related solely to timing? Im no tuner by any means, but I always hear that its timing that makes power, not boost. So, if they are pulling "X" amount of additional timing to increase boost from 10 to 15psi, wouldnt that negate any gains? Could be that they are just tuning to what they are comfortable with?
#223
Well there you go, its the tune, not the set up per say. Your tuner felt best given the boost amount, to curtail the timing advance, because risk of detonation at the top end. More timing can obviously be had in the lower rpms and benefit the overall power band with the higher boost there.
#224
S2000junky said it for me " Probably feels like a light switch with power delivery at WOT from low rpm to when boost comes on. Not sure how that would be to control on a road course at the limit, or how smooth your partial throttle is under partial load/minimal boost in the mid range where the turbo is begging for gas pedal, but I’m sure you will get a good sense of that in time and can better compare the drivability and forgiveness between the two."
Not sure if I want to have a car that I drive on the street in the twisties or on the track to have the power delivery of a light switch. Yes it spools super fast but like anything too much of a good thing is not always the best thing. You have so much more under the curve for both HP and torque(say at 5200 RPM you have 70 more ft/lbs and 70 more HP than a SC, lol not even talking about over stock). But will you miss running the car up 9,000 RPM? After 7K you have nothing more. I am sure you will not miss the 19 HP you lost on the top end. Again these are numbers we can BS about forever. I really want you to put sevearl hundred miles and a track day on the car and see what your actual driving experience is like.
#225
#227
Looks like this kit is begging for E85 and more timing in the upper end. I know from past experience that King Motorsports tend to err on the conservative side which is not a bad thing.
Dustin, have you thought about taking a nice drive up to LJ at Fullblown and let gim have a crack at tuning the car? Just a thought.
In the end its your car and you have to please no one but yourself!
Sent from my SAMSUNG-SGH-I337 using Tapatalk 4
#228
I prefer a conservative tune over agrressive one. If you cannot run more timing due to detonation, It is obviously a setup issue not a tuning issue. Keep in mind im on a 2.2l not a 2.0l. The amount of timing you rjn changes between the two engine. One sits at tdc longer than the other and as a result dictates the amount of time you can run.
Tuning the car on race gas will net more power, but it will still end up with a flat lined graph near redline
Sent from my Samsung Galaxy S4 now Free
#229
