SOS TS Max Turbo Kit Build Thread
#153
That's the water-cooled center housing doing it's job. The coolant is boiling causing the gurgling noises and siphoning in more coolant.
#156
Originally Posted by LilJoe' timestamp='1380820242' post='22809323
I was thinking they may have sent you my map, but then I remembered you're not on AEM. Curious what your car will make compared to mine.
Ill see if Mike will send me your dyno graph for comparison, with your approval of course ;-)
As far as I know King has not announced a dall dyno day. I will talk to Scott on Monday morning about it, and hope I do not work the projected day of the dyno day.
Sent from my Samsung Galaxy S4
#157
Turbos run a lot hotter then SC. Timer isn't a bad idea to protect the investment.
Dustin, I forget if you had your 1200 running at max rpm or not (aka 3-3.2") if you did I would be curious to know what your thoughts on the Turbo is in comparison. I realize there is going to be more mid range power because the turbo can produce full pressure in the mid range unlike a sc, but how about the pull at the upper range... full out, when ripping through the gears?
