SOS TS Max Turbo Kit Build Thread
Old 09-27-2013, 04:55 PM
  #101
passmans2kny's Avatar
looks great, in for results
passmans2kny is offline
Old 09-27-2013, 06:35 PM
  #102
RAIN H8R's Avatar
I finished installing the kit today. Ive got some welding that needs to be done and a tune. I ended up going back to the -8 oil drain.
Sent from my SCH-R970 using Tapatalk 2
Attached Thumbnails SOS TS Max Turbo Kit Build Thread-uploadfromtaptalk1380335458257.jpg   SOS TS Max Turbo Kit Build Thread-uploadfromtaptalk1380335472851.jpg   SOS TS Max Turbo Kit Build Thread-uploadfromtaptalk1380335488389.jpg   SOS TS Max Turbo Kit Build Thread-uploadfromtaptalk1380335501921.jpg
RAIN H8R is offline
Old 09-27-2013, 07:05 PM
  #103
Member
Spotter
kryptonite's Avatar
Looks like a really tight squeeze. Any concerns about that?
kryptonite is offline
Old 09-28-2013, 06:14 AM
  #104
Jmays2k's Avatar
From the pics it does look really tight when the motor rocks will it not hit the side? I think that is why inline pro use to cut a gap at that spot.
Jmays2k is offline
Old 09-28-2013, 06:15 AM
  #105
camuman's Avatar
I'm pretty sure sos put this setup thru it's paces. They are far from hacks
camuman is offline
Old 09-28-2013, 06:53 AM
  #106
Jmays2k's Avatar
I agree for this is the kit im getting as well just from the pics its a little closer then I expected is all. I dont see how the heat shield fits even though I have seen the pics where it does so IDK maybe its just the pics
Jmays2k is offline
Old 09-28-2013, 08:24 AM
  #107
herecomesboost's Avatar
Looks great!
herecomesboost is offline
Old 09-28-2013, 08:27 AM
  #108
tx2K's Avatar
Looking good
tx2K is offline
Old 09-28-2013, 10:02 AM
  #109
RAIN H8R's Avatar
I have no concerns at all. The black heat sheild fits no problem and the bolt closest to the firewall is super easy to get to.
The downpipe flange to the turbo was difficult to do. One of the bolts is between the wastegate hole and the block. If your talented with all 5 of your fingers youll do great If you follow the directions in order you will be fine.
RAIN H8R is offline
Old 09-28-2013, 11:57 AM
  #110
06S2k07Si's Avatar
Looks great! What welding? Nothing with the kit I would guess?
06S2k07Si is offline
Quick Reply: SOS TS Max Turbo Kit Build Thread
