SOS throttle body fix tps issue with meth?
Originally Posted by S2Kart,Nov 15 2010, 07:07 AM
Thanks Sarge. Before I added the hole the TPS would have condensation on it but it seems to stay dry now.
So on the factory TB does that shaft seal get damaged from meth and start leaking air? The weep hole sounds like a good idea, but I would not want an air leak there. If not then I may give this a try.
I use dentured alcohol/water mix instead of methanol due to I don't want to use something as corrosive as meth. The water does the lion's share of heat removal anyway, the additive is just to prevent the water from freezing.
tom153
02-27-2013 04:20 PM
