Smogable
Smogable
will adding a comptech s/c and a j's racing header not let the S pass smog or will it still be able to pass smog.
I live in CA, which has the strictist emmisions rules around so I want to make sure it would pass before I go that route.
Thanks
Thanks
Also remember that even though it may pass the sniffer.....it will fail the visual inspection. Each aftermarket component needs to have it's own CARB EO and the Header will not pass.
Solution is to get the Comptech S/C and the Comptech Header.
what if you upgrades to a smaller pulley, and using aem ems, and rc injectors, can you still passed smog? or do you have to plug the stock ecu back? what about the injector?
Originally Posted by my01s2k,Nov 16 2005, 09:37 AM
and how do you make it passed smog? by putting back the OEM ECU and the oem injectors? or just the ecu is fine?
