Smallest pulley for stock CTSC
Old 10-27-2007 | 03:22 PM
dean's Avatar
Originally Posted by raymo19,Oct 27 2007, 07:15 PM
So what diameter pulley is that for the Comptech?
Do a search noob.
Old 10-27-2007 | 03:23 PM
Enthralled's Avatar
Originally Posted by dean,Oct 27 2007, 04:12 PM
Thanks. I didn't realize the VTSC and the CTSC put out different amounts of boost. Everything that I've read on the two indicates that they both put out about the same amount of power.
stock Vortech should put out about 15-20whp more.
Old 10-27-2007 | 03:26 PM
dean's Avatar
Originally Posted by Enthralled,Oct 27 2007, 07:03 PM
this is my AP2 Vortech, see the extra injector coming from the aftercooler.
Thanks for the pic. Does that injector clear the radiator hose? They look to be very close in the pic.
Enthralled's Avatar
yes, it fits fine. no rubbing at all.
Old 10-27-2007 | 03:30 PM
dean's Avatar
Is yours stock? And what are you putting down at the wheels?
Old 10-27-2007 | 03:45 PM
Enthralled's Avatar
tuned with an Emanage Ultimate on 9psi. 322whp/211tq . the red is when i was at stock boost using the Vortech blackbox.312whp/206tq
I've ordered the 10psi pulley from ASP, but i may just sell my kit and move on to a turbo.
Old 10-27-2007 | 06:52 PM
raymo19's Avatar
Originally Posted by dean,Oct 27 2007, 07:22 PM
Do a search noob.
Yeah - I tried that. Lots of interesting reading but nothing on topic.
Old 10-27-2007 | 07:02 PM
EriS2k's Avatar
7psi should be right with no Injectors!
Get 650CC Injectors, EMS and 14psi SOS Pulley (3' Pulley)
400WHP Easy!
Old 10-28-2007 | 10:13 AM
dean's Avatar
Those are some very nice numbers.
Not to start a pissing match, but which kit, out of the box is the most friendly with pre-existing mods? I'm running an Invidia header, SuperSprint exhaust (65mm), and a high flow cat. I would like to run the SC with just the black box/ESM for a while until I can get the Emanage Ult. set up and tuned if it's not going to create any problems.
Old 10-28-2007 | 02:40 PM
Enthralled's Avatar
they should both be about the same.it's the same type of charger, just running different boost levels out of the box.
Quick Reply: Smallest pulley for stock CTSC
